tapkaJohnD wrote:I have a Mk6 350 TD, 2011. I'd like to add a tachometer/rev counter, not by fitting a 'proper' tacho-containing dash from a Mondeo, but just in a pod on top of the dash.
I read that a tacho can be fitted to a diesel, by connecting it to the "W" terminal on the alternator, but my Halfords manual doesn't show a W on the alternator in the wiring diagrams.
Is there one on my van? Is this a much more complex wiring project than first appeared?
Thanks,
John
knobby1 wrote:tapkaJohnD wrote:I have a Mk6 350 TD, 2011. I'd like to add a tachometer/rev counter, not by fitting a 'proper' tacho-containing dash from a Mondeo, but just in a pod on top of the dash.
Thanks,
John
2011 will be a Mk7 and they all had a tachometer....I suspect you have a 2001..?? There were Transits of that age with tacho's in the clocks, not sure if they're a plug 'n play thing though.
Fitting a "pod" type tacho may be an issue as there is no normal igntion source like a petrol engine...but Mk6 diesel Transits with a tacho get an rpm signal from the PCM/crank sensor I suspect.
Other chaps/chappettes may know better.
tapkaJohnD wrote:Thanks! Yes, my mistake, 2002, not '11!
Close examination of my Transit's alternator finds that Halfords' diagram almost exactly matches it! Large cable (for charging), three wires to multiway plug, Black, Red, Green/white. (Halfords shows two reds)
So no 'W' terminal, no hope of rigging a tacho to that.
If this model had no tacho, will it have an unused wire to the dash that would carry a tacho signal? Can anyone point me to a wiring diagram that would show that wire, if it exists, and let me find it behind the dash?
A link, please, if you can!
John
tapkaJohnD wrote:Thanks, ned.
But I note this comment in that post:
"You will not be able to put the tacho wire in because its not there. You will need to run a wire from Large plug pin 8 to the Coil -ve on a petrol and the 3rd terminal on the Alternator IF ITS THERE CHECK THIS FIRST"
And I have, it's not there.
Think I'm giving up on this project! Too much hassle for a bit of bling!
thnaks to all!
John
