rocchettanervina wrote:2001 Ford Transit headlight level motor removal. I thought I'd post this as I had a great deal of trouble trying to remove and refit a new motor. The most important point is to make sure the spindle of the motor is extended to its greatest length or else you won't be able to get it out or the new one in. It wasn't until after a great deal of trial and error that i realised this. Also, when removing or installing the motor it's not a straight in line pull out or push in. You have to angle it slightly so the "ball" at the top of the motor shaft slides a few mm to one side and out of the rebated channel in which it sits.It's not easy to know exactly which was to angle it when removing but a close inspection before installing a new motor should become evident.
Users browsing this forum: metalworker0, T350camper
