So my 2012 260S Trend Euro 5 is causing some grief when warm starting
Cold doesn't miss a beat , started on first turn of the key no hunting or other irratic behaviour
Warm / Hot I need to hold the key on crank for a few more seconds and eventually will start and tickover as normal but during those few brief seconds sounds like a bag of bolts
I've changed the injector leak off seals and cleaned the cam sensor so far - no joy
I'm fairly sure this started after clutch and DMF install , but it had a new crank sensor at the same time
I'm getting RPM and Sync on cranking ( see attached ) and fuel pressure seems ok - so now lost - anything else I can try on ForScan ?
Any other ideas ? - could the crank sensor be too close to the flywheel ?
