marc1234567 wrote:it's a left hand thread and I'm stupid so I broke it.
the sprocket doesn't come out. is there a thread in the sprocket or can I pull the sprocket?
knobby1 wrote:marc1234567 wrote:it's a left hand thread and I'm stupid so I broke it.
Does the sprocket not have a big nut/bolt in the middle which drives the fuel pump..??
marc1234567 wrote:just saw a sprocket and there's no thread on the sprocket. just tapered.
knobby1 wrote:marc1234567 wrote:just saw a sprocket and there's no thread on the sprocket. just tapered.
Yeah...they usually need a puller to remove the sprocket, that's what the two holes in the sprocket are for.....Don't like you chances of getting the remains of the old bolt out of the pump drive shaft either.
Puller is something like this..::
marc1234567 wrote:I suspect keeping the sprocket in place while I attempt these actions is probably best way . do you know if the would be a way stop the pump shaft turning without sprocket there?
knobby1 wrote:marc1234567 wrote:I suspect keeping the sprocket in place while I attempt these actions is probably best way . do you know if the would be a way stop the pump shaft turning without sprocket there?
Not that I'm aware of....not had this sort of issue. Leave the sprocket & chain on maybe....failing that, you might have to remove the pump and hold it in a vice...but still leaves the problem of how to hold/stop the shaft from turning.
metalworker0 wrote:There are stud removers that work both ways, clockwise and anti clockwise .
if nothing works ..last ditch attempt would be you welding a nut onto it , once you remove the pulley ..me thinks.
probably end up burning the seal though .
metalworker0 wrote:showing snap on one taken apart ..with two directional barbs
Jim Archer wrote:Unless there was threadlocking compound used, that bolt will likely just spin out if you can get purchase on it. The bolt was just there to hold the tapers together whilst heat and vibration do their best to loosen the fit. Did it have a Belville (dished) washer?
As you are taking the pump off, it's likely easier to do on the bench. Just lightly tap the sprocket back on the surgically clean tapers.
Jim
