SteveJeff wrote:there does seem to be some similarities with the datsun lol
Think they call that rust
1888 wrote:SteveJeff wrote:there does seem to be some similarities with the datsun lol
SteveJeff wrote:Hi folks,
I have had another look at my van today and had a bit of help from a friend so that i can see what is going on whilst trying to start it....... there appears to be lots of air in the fuel system. I changed the Fuel filter again but still the same. I put a pipe from a jerry can through a hand primer pump ( rubber squeezy ball type thing ) onto the high pressure pump pick up pipe and then a pipe from the leak off pipes back to the jerry can. I pump the hand primer to get rid of most of the air and then tried to start the van. It would still only start with brake cleaner but it seemed to produce quite a lot of air through the return pipes but also the fuel pump didnt seem to be sucking the diesel through from the jerry can...... am I right in thinking that the high pressure pump is screwed ? and could this have been the reason why it didnt like starting once it was hot ?? or could it be the valves on the pump as opposed to the pump itself ?
Anyone know how difficult a job this is on a 2.4 rwd and also if it is the pump will it need coding or teaching in before it will work ?
thanks again for any help or information given
SteveJeff wrote:Thanks for the replies everyone, I have not been able to get back on the van for a couple of weeks but will hopefully be back on it soon. I will update with any progress. Thanks for all the input and information given.
Nobby,
I have ordered injector leak off o-rings and new copper sealing washers as I have already messed around with the injectors so wanted to replace everything that had been disturbed!! Fingers crossed I can actually get the thing running again very soon
Thanks for your time and information.
SteveJeff wrote:Right guys,
A quick update, I have changed o rings on injector return pipes, fitted a new genuine fuel filter, new scv, new prv, new egr valve, new inlet manifold gaskets.
According to FORscan I have 7000kpa fuel pressure during cranking, the bloody thing still doesn't start, can't do a pump learn as it needs to be running...... any suggestions guys or am I missing something really stupid ? Is that fuel rail pressure enough during cranking ?
Steve
SteveJeff wrote:Yes she starts with brake cleaner no problem. I did fill the original fuel filter to the brim and then it broke down after about a 10 minute drive. ( Pattern filter ) I have since changed to a genuine filter and filled to the brim but still won't start on diesel. It won't keep running after brake cleaner has dispersed.
What would be the best way to clear air if it is air in the system, I have a small 12v fluid pump if that will help Thanks Steve
