sauzee wrote:I swaped sensors fault still on the same side Do any of you guys know where i can get a wiring diagrami bought the Haynes manual but no wiring i also bought an online manual but no wiring either
So if anyone has or knows where i can purchase the wiring diagram Thanks
knobby1 wrote:sauzee wrote:I swaped sensors fault still on the same side Do any of you guys know where i can get a wiring diagrami bought the Haynes manual but no wiring i also bought an online manual but no wiring either
Most of the non Ford manuals are just generic Transit ones, especially the Haynes manual...there's so many variants of the transits.... and covering all of the variants would be quite a task and the manuals would be huge.
I find the BEMM to be quite useful for wiring etc... It's to be found on the Ford ETIS website...but you need to be registered to download now I think.
sauzee wrote:knobby1 wrote:sauzee wrote:I swaped sensors fault still on the same side Do any of you guys know where i can get a wiring diagrami bought the Haynes manual but no wiring i also bought an online manual but no wiring either
Thanks i looked on their site but wont even let you look without registering.Today i went back to the start and removed the chain cover to check timing marks which i think may have not had both cams synced as one of the pins would not lock in without slacking of the bolts on a cam so i will rebuild it tomorrow and see how it runs hopefully stop revs sticking and limp mode
sauzee wrote:Thanks 1888 i dont have fuel pump on the timing but i took out no1 injector with the pin locked at sensor and a long screwdriver in the hole it was about 50 degrees took out pin turning anti clockwise till cams lined up and front crank tool in rotated tdc then down about 50 degrees and so marks must be right just a fault so only thing i can think of is flywheel changed and that is what is 180 degrees out so will finish putting together tomorrow and see how many fault codes Thanks
