Mk6 rwb transit 90psi block same as 125psi
Re: Mk6 rwb transit 90psi block same as 125psi
Postby knobby1 » Wed May 18, 2022 9:41 am
trannyfreak wrote:Does it need a gasket between the cam cradle and head or is it just sealant? Many thanks
No gasket on them....just a light smear of sealant.
http://www.catcar.info/ford/?lang=en&l= ... I3Mg%3D%3D
Postby trannyfreak » Wed May 18, 2022 4:15 pm
Thanks knobby, one last thing sorry, on the 90psi engine the head gasket had 3 notches on it my 125psi engine has got 2 notches on it, I brought a head gasket off ebay and its came with 3 notches, as I'm putting the head off the 125psi on to the 90psi block will the 3 notch gasket be ok?
trannyfreak
Postby knobby1 » Wed May 18, 2022 8:07 pm
trannyfreak wrote:Thanks knobby, one last thing sorry, on the 90psi engine the head gasket had 3 notches on it my 125psi engine has got 2 notches on it, I brought a head gasket off ebay and its came with 3 notches, as I'm putting the head off the 125psi on to the 90psi block will the 3 notch gasket be ok?
BTW, it's "90PS or 125PS" not "PSI". PS is essentially a metric horsepower rating, very close to BHP.....1 PS is equal to 98.6% of 1 BHP.
PS stands for "Pferdestarke" in German.
There's a measurement you make to determine the head gasket thickness required, this below is for the Mk7 but I believe the procedure is the same for Mk6.
Postby trannyfreak » Wed May 18, 2022 8:42 pm
Ah ok thanks mate, so really as its the 90 engine the 3 notch gasket will be ok, thanks for the advice knobby I will leave you in peace for now mate :)
trannyfreak
Postby knobby1 » Wed May 18, 2022 8:48 pm
trannyfreak wrote:Ah ok thanks mate, so really as its the 90 engine the 3 notch gasket will be ok, thanks for the advice knobby I will leave you in peace for now mate :)
Don't mind helping if I can....I've certainly received plenty of help/advice from others on here.
Postby trannyfreak » Sat May 21, 2022 10:33 am
I'm changing rear crank seal does the new one need sealant? Also changing the spigot bearing as that has calloused, I got the old one out does the old one need any tricks putting it back in like putting in the freezer or smearing with grease and tapping in, or just the case of tapping it back in just as out of the box? Many thanks
trannyfreak
Postby scas » Sat May 21, 2022 11:01 am
trannyfreak wrote:I'm changing rear crank seal does the new one need sealant? Also changing the spigot bearing as that has calloused, I got the old one out does the old one need any tricks putting it back in like putting in the freezer or smearing with grease and tapping in, or just the case of tapping it back in just as out of the box? Many thanks
no sealant and just tap the spigot in
06 mk6 2.4 di 115 remapped by martyn
04 mk6 2.4 di 115 remapped by martyn
04 mk6 2.4 di 90
05 mk6 2.4 di 115
new 06 mk6 2.4 di 115
new 00 mk6 2.4 di 125
can you see a pattern
scas
Postby trannyfreak » Sat May 21, 2022 12:10 pm
That's brilliant thanks mate
trannyfreak
Postby trannyfreak » Sun May 22, 2022 10:42 am
What's the best way to tap in the spigot bearing without damaging it?
trannyfreak
Postby knobby1 » Sun May 22, 2022 7:56 pm
trannyfreak wrote:What's the best way to tap in the spigot bearing without damaging it?
A socket a tiny bit smaller than the OD of the spigot.
Postby trannyfreak » Mon May 23, 2022 9:45 pm
Thanks knobby mate
trannyfreak
Postby trannyfreak » Tue May 24, 2022 12:08 pm
Can anyone tell the torque settings for the crank shaft timing chain sprocket bolt, not the bolts that hold the pulley, many thanks
trannyfreak
Postby trannyfreak » Tue May 24, 2022 10:34 pm
With the timing chain tensioner when you pull the pin out does the tensioner come slightly out or does it need to come halfway out,is there any info on how to properly set the tensioner many thanks
trannyfreak
Postby knobby1 » Tue May 24, 2022 11:12 pm
trannyfreak wrote:With the timing chain tensioner when you pull the pin out does the tensioner come slightly out or does it need to come halfway out,is there any info on how to properly set the tensioner many thanks
Tensioner will "set itself" when oil pressure is applied.
Postby trannyfreak » Wed May 25, 2022 12:44 pm
Brilliant thankyou do you know the part number for the tensioner? Many thanks
trannyfreak
Users browsing this forum: Chug, Majestic-12 [Bot]
