frosty125 wrote:Any suggestions about how to prime a remanufactured 2.2 engine?
knobby1 wrote:frosty125 wrote:Any suggestions about how to prime a remanufactured 2.2 engine?
Euro-4 or Euro-5..?? You don't say which you have..??
Either way Mk7's are self priming, Euro-5's also have a lift pump in the tank.
With the Euro-4's, just fill the fuel filter with fuel and crank it, if everything is working properly, she should start in less than 10 seconds.
frosty125 wrote:knobby1 wrote:frosty125 wrote:Any suggestions about how to prime a remanufactured 2.2 engine?
Euro 4 and sorry I meant oil priming.
frosty125 wrote:How long should it take? I've turned it over with the starter a few times about 10s a time and oil lamp is still lit and the live dish data show oil pressure low.
knobby1 wrote:frosty125 wrote:How long should it take? I've turned it over with the starter a few times about 10s a time and oil lamp is still lit and the live dish data show oil pressure low.
Is it a Euro-5..?? They're known to have a chocolate oil pump.
Oil pressure at cranking speeds of ~400rpm won't be much.
frosty125 wrote:Euro 4, it's a new oil pump, there is oil getting to the filter, I started to undo it and oil was coming out. It has a new turbo core fitted as well so I might try and disconnect the turbo oil return to see if it's getting oil. Is there a chance that cranking speeds are not enough to turn the oil light off?
knobby1 wrote:frosty125 wrote:Euro 4, it's a new oil pump, there is oil getting to the filter, I started to undo it and oil was coming out. It has a new turbo core fitted as well so I might try and disconnect the turbo oil return to see if it's getting oil. Is there a chance that cranking speeds are not enough to turn the oil light off?
Minimum oil pressure at idle when warm is only ~18psi, so when cold it should easily be more than tat at cranking speeds....and it should put the light out.
Maybe the pressure switch is no good.
frosty125 wrote:I removed the oil filter holder and turned it over to see if the pump was shifting oil which it does seem to be. But with the oil filter holder mostly unscrewed oil was not leaking when cranking with the starter which suggests low pressure?
knobby1 wrote:frosty125 wrote:I removed the oil filter holder and turned it over to see if the pump was shifting oil which it does seem to be. But with the oil filter holder mostly unscrewed oil was not leaking when cranking with the starter which suggests low pressure?
Was the oil pick-up tube fitted to the bottom of the oil pump...in the sump..?? Sillier things have happend.
frosty125 wrote:knobby1 wrote:frosty125 wrote:I removed the oil filter holder and turned it over to see if the pump was shifting oil which it does seem to be. But with the oil filter holder mostly unscrewed oil was not leaking when cranking with the starter which suggests low pressure?
I assume it was, the engine was delivered with sump fitted and sealed. I would have thought it could not pump any oil if the pick up wasn't fitted.
knobby1 wrote:One would assume so. Possibly an "air lock" in the oil pump maybe..? Unlikely though.
frosty125 wrote:knobby1 wrote:One would assume so. Possibly an "air lock" in the oil pump maybe..? Unlikely though.
Are there any seal leaks that would cause low pressure? Such as front/rear crankshaft seal, turbo feed, fuel pump, vacumn pump, oil filter housing?
