I bought at second hand 2013 mk7 Transit a week ago. I drove it home from the dealer, about 1.5 hour drive. No problems at all. Later the same day I took it out to get diesel and the engine management light came on. I notified the dealer straight who said it is probably the MAF sensor, but to get the codes read and we can take it from there.
I took it to a local garage and the fault codes came back as P0104 - Mass or volume air flow circuit and P0691 - Fan 1 control circuit low.
I have done a bit of reading and investigating about the P0691 and I think it most likely the relay causing the fault. The fan fuse looks ok, fan blades spin freely and the engine it’s not overheating either whilst driving or idling.
I am returning the van tomorrow and the dealer will replace the MAF sensor, but says the relay is probably a historic fault.
Is this likely to be the case? I feel that it has probably recently failed i.e. the day I bought the van and it should be replaced at his cost along with the MAF sensor.
Is that a reasonable assumption? And is the dealer liable for all repairs to issues that come to light after purchase?
Any knowledge, advice, wisdom gratefully received.
Cheers all.
