m25roundabout wrote:Thanks TheCake, will do. Not being a sparkie I can't understand why there are only 6 wires going into the back light cluster when there are four lights to light. In my limited knowledge I would have imagined there would be two wires for each light, hence a total of 8. But it all looks correct as there are no other connectors there. Thanks again. Will do what you say.
Hi Ned, I undid the switch from the gear box and tested it. It worked.ned wrote:How do you know the switch on the gearbox works?
Altransit wrote:m25roundabout wrote:Thanks TheCake, will do. Not being a sparkie I can't understand why there are only 6 wires going into the back light cluster when there are four lights to light. In my limited knowledge I would have imagined there would be two wires for each light, hence a total of 8. But it all looks correct as there are no other connectors there. Thanks again. Will do what you say.
Side Light
Brake Light
Fog Light
Reversing Light
Indicator Light
Common Earth Return
viewtopic.php?f=40&t=166333
m25roundabout wrote:ned wrote:How do you know the switch on the gearbox works?
Ned, apologies, and thanks for the prompt! I thought I knew how to test the switch. Obviously I didn't! I bought a new one just to try it. Just fitted it. Two beautiful bright white lights now eminating from the rear of the van when in reverse. Cheers!
