metalworker0 wrote:Well the end seen on hitch hikers guide of that fellow in a bath, tells you all you need to know about what's around the corner.
Use of my bus pass and riding a bicycle is what i got used to when my van was off the road, got so used to it, that when the fuel price went up, i now wonder why i bought a van.
Getting so bad that horses and carts may make a come back, bicycle and hand pulled rickshaws are doing well in London
Are we regressing.
tranmx2 wrote:Thank you for the reply re' Transit Tech Hull.
Called them and they are to send an email.
I have contacted several companies by email or via the web page.
Some have replied but most have not.
One sent a quote which was for a 2.2 RWD E5 engine. No info' re which one.
On a list of codes that I have.
There are 4 2.2 100 HP engines with different codes DRFA, DRFB, DRRA, DRRB.
The 2.2 engine can be 100, 125,155 HP the codes are different for the 125 and 155 engines and there are more codes for the FWD.
Question: How do you get 155 HP from the an engine that is also 100 HP where both are 2.2 ltrs ?
The two persons at two different companies that I spoke to today did not seem to know about the Ford engine codes.
tranmx2 wrote:Thank you for your reply.
All the Euro-5 engines are essentially the same, it's basically the PCM mapping which determines the hp/ps rating.
All 2.2 ltr with 100 to 155 HP produced by changing only the injector timing and the amount of fuel injected. Is changing the timing of injection and the amount of fuel injected the only two things that can be changed by the PCM to alter the power output of the engine?
In the 70s the power output of an engine could be changed by fitting a different camshaft, a different carburettor, changing the spark timing, fitting a different spark plug, a different piston, a different cylinder head, a different thickness of head gasket, different valves, changing the cylinder bore ID, changing the shape of the inlet/exhaust system. Tuning the engine with whatever was fitted/changed. If increasing the HP the crankshaft etc would likely need to be larger/stronger.
Can a modern engine which is mechanically the same have its HP increased by 50 % by only altering the injection timing and amount of fuel injected?
The info' of the 4 RWD 100 HP engines in the code list is the same. There are 4 100 HP engines with different codes for each one however the info' is the same.
Why have the various codes?
Why are there 3 thicknesses of head gaskets, 1.00 mm, 1.2mm, 1.5mm?
The 100 HP engine from my van has the 3 hole/notch head gasket which is 1.5mm (0.047") thick.
Is it the original fitted gasket or was the head skimmed then a thicker gasket fitted to maintain the clearance between the bottom of the valve and the top of the piston?
Are the 3 gasket thicknesses used to change the compression ratio and therefore the HP?
I have spoken to 3 engine recon'/reman' companies.
Their responses have caused more questions to be asked or they have not responded with answers to questions asked.
One told me that the recon' engine would be sent to a hub in a city. I'd need to arrange collection - no address of the hub was given.
If I receive an engine that is not DRRB code does it mean that the PCM shall need to be reconfigured for the code of the engine that is sent?
knobby1 wrote:I work on aviation turbine engines for a living and fuel/boost pressures can certainly make a huge difference in performance.
I also crew for a Top Fuel Dragster team. The engine is essentially a 500ci two valve, pushrod V8 engine loosely based on the Chrysler Hemi V8 engine, they made about 300hp in stock trim, a Top Fuel engine with a high boost blower and 85% nitro methane fuel transform it into a 10,000hp+ fire breathing monster. Take the blower and nitro fuel away, run it on normal fuel with no boost and it would return it to a placid 300hp engine again, so we're looking at over 1000% increase in performance just through boost and fuel changes...so yes, fuel type and quantity....and boost pressures can make a huge difference.
If you throw more fuel and higher boost pressures at a basic Transit engine, you could easily get 200+hp out of it, how long it would last doing that is a different question.
andypdq wrote:Do the dragsters still use magnetos?
