The combat wombat wrote:Got a strange starting issue on our MK6. Most of the time it starts straight away, but other times it will turn over, start to fire, but then cut out. Yesterday it caught, but then sat at tickover and pushing the throttle pedal did nothing. I had to turn it off and after several attempts it then fired up and would rev properly.
Any ideas what could be causing this?
No warning lights, although I did notice that when it was on a non-responsive tickover, the oil light was flickering. It's just been serviced, all new filters, oil change and a split turbo pipe replaced, so when it runs, it's responsive and now has plenty of power - so long as it actually starts!
knobby1 wrote:
What engine oil did they use..?? If the engine doesn't get to ~800rpm at idle after stating, the throttle is disabled until it gets to a stable idle.
Have you had the codes read..?? You don't have to have a flashing glow plug light to have fault codes stored.
I'm not sure on the engine oil, but I presume it was a good one as he only uses genuine parts for filters, etc. but I'll ask. It was also doing this before the service, but I he had a lot to do and probably forgot to check the codes.
I've got a cheap and cheerful reader and it won't recognise the transit, although it's fine on my 08 Volvo! I'll take it back and get my guy to read the codes, see what's going on.
knobby1 wrote:Forscan and a modified ELM-327 are the go to for Mk6/7 Transits.
Chug wrote:Get one of these Modified ELM 327 from Steve Elmer @ Tunnel Rat Electronics here https://tunnelrat-electronics.fwscart.c ... 45457.aspx
Download and Install Forscan here https://forscan.org/download.html
The combat wombat wrote:knobby1 wrote:Forscan and a modified ELM-327 are the go to for Mk6/7 Transits.
Will this work?
https://www.ebay.co.uk/itm/333969600157 ... SwupFggDib
TIMO wrote:my pedal on the way out,,,occasionally she stays on tickover and refuses to rev up
knobby1 wrote:Don't use WiFi or Bluetooth units...they tend to be rather "flakey" at best and can "drop out" at the most inopportune times causing lots of grief.....Use the cable one Chug has linked to.
The combat wombat wrote:TIMO wrote:my pedal on the way out,,,occasionally she stays on tickover and refuses to rev up
It's only done the tickover thing once, the rest of the time it won't even fire. Not to say the pedal isn't at fault, but I will see what the garage says.
