ned wrote:I had that issue on my mk6 years ago and it turned out to be the starter motor, new one sorted the problem
Captain chaos wrote:ned wrote:I had that issue on my mk6 years ago and it turned out to be the starter motor, new one sorted the problem
thanks for the reply, starter flies over every time quite sure its fine. never happens when its cold , only when its been on a run
knobby1 wrote:Captain chaos wrote:ned wrote:I had that issue on my mk6 years ago and it turned out to be the starter motor, new one sorted the problem
Could still be the starter, quite a common issue on the Transits....if the starter is not at it's best it will draw more current & voltage when warm than it does when cold.... pulling the battery down below what the rest of the engine systems need to live, this leaves precious little for the fuel pump electronics to operate correctly, hence the poor starting when warm. A new or re-con starter often cures the issue.
Captain chaos wrote:is the diesel fuel pump mechanical or electric?
ant_harvey wrote:Hi - I think I have the same issue with my van, cranks fine when cold but doesnt always sound like its engaging when up to temp and takes quite a few goes to start, then runs fine. Did you solve the problem? Thanks
savi18 wrote:ant_harvey wrote:Hi - I think I have the same issue with my van, cranks fine when cold but doesnt always sound like its engaging when up to temp and takes quite a few goes to start, then runs fine. Did you solve the problem? Thanks
My starts first time when cold but when hot spins over really fast but none starter, if i pour cold water from water hose over injection pump for around 20 seconds it starts first click, have had to do this around 10 times and always starts with the cold water trick, you can give it a go and let us know, my problem seams to be the edc does not like getting hot and cold water cools it down, however when it does start from the cold water trick it runs fine all day 2003 2.4TDDi 90ps rwd.
ant_harvey wrote:I will give that a go tomorrow, if it works does anyone know what the solution is (apart from carrying a watering can around!)
knobby1 wrote:ant_harvey wrote:I will give that a go tomorrow, if it works does anyone know what the solution is (apart from carrying a watering can around!)
Have you had the fault codes checked..?? You could have a poorly EDC on the pump.
ant_harvey wrote:I have run tests with my ELM 327 and no codes shown for any modules.
