I have a 2011 MK6 with 2.2 Duratorq engine. I bought it in may 2021 an have driven it about 4000 km and I got receipts that the clutch and flywheel was replaced just before I bought it.
Now I have a noise that goes away when I press the clutch in and from what I understand this is the Clutch release bearing?
In the beginning I had some issue where the clutch pedal did not come all the way out so I put my foot under the pedal and lifted it up. Could it be that it somehow has been half engaged and been wearing it out?
I don't know if they replaced the clutch release bearing when the flywheel and clutch was replaced.
I am going to take out the gearbox and replace the clutch release bearing, but thinking it shouldn't be necessary to replace the flywheel again? I need to order some parts for the job. Is there any other parts than the clutch release bearing I should replace?
