Hi all,
Been away from the forum (and my van) for quite a long while now... finally need to sort it out and get it back on the road.
Symptoms:
1) My fuel filter is emptying itself.
2) Starts on the button, but as soon as I touch the accelerator it coughs a few times with the revs pulsing, then dies.
3) The dreaded DTCs P1664 and P1564 appear.
4) If I clear the DTCs, prime the filter, then start the van without touching the accelerator, then shut it down again after 30 seconds or so... no new DTCs
It took me a while but I had finally resigned myself to replacing the injection pump, but thought I better take the fuel filter assy out to check for cracks etc and any other problems first.
This is what I noticed:
Does this look like I might have found the source of my air leak to anyone else?
When I look inside the pipe fitting on the flow from the filter to the pump I see more clues:
Compared to the pipe fitting on the flow from the tank to the filter:
Here are my questions:
1) What are the chances the air leak is starving the pump of fuel and causing those DTCs, rather than an actual pump failure?
2) Is it worth me reassembling everything and replacing that pipe between the filter and the pump in case it solves my problem first before sending the pump off and forking out for a new one?
3) Are those fuel line pipes only available from Ford, or does anyone else know of a better value source? This seems to be the part number: 4696413 or YC159289ED found here:https://www.ebay.co.uk/itm/Genuine-Ford ... 3530174675?
4) Is it worth trying to replace the O-rings inside the fitting or should I just by a whole new pipe set?
