Snapped The Tensioner
Postby enjoythistripp » Tue Aug 16, 2022 8:30 am
Ok so van was seized after three years idle. Followed advice to remove drive belt.
Soon as I put any pressure on the bar the groove shattered. Ended up cutting belt and engine ran sweet first turn.
Had a good search but can't find exact thread. Is the tensioner just unbolt and replace? Or do I need to do timing as well?
Thanks in advance.
You can take a man out of a transit but you cant take the transit out of the man
T350 2.4 TDCi Xlwb Luton 115ps 2007
enjoythistripp
Re: Snapped The Tensioner
Postby knobby1 » Tue Aug 16, 2022 9:48 am
Assuming Mk7 RWD..?? The belt is "NOT" a timing belt, it just drives the engine accessories, water pump, power steering, alternator, air conditioning. Mk6/7 Transits have a timing chain.
On the RWD's the tensioner assembly is held on with a single bolt.
Mk7 2.4 RWD here..:
http://www.catcar.info/ford/?lang=en&l= ... k3ODYrMTMz
Postby enjoythistripp » Tue Aug 16, 2022 9:53 am
Sorry MK7 t350 XLWB Luton. Think. It's fwd. Looking at that diagram it's not the tensioner itself, it's the part that you fit the 1/2 inch bar into.
enjoythistripp
Postby knobby1 » Tue Aug 16, 2022 10:09 am
enjoythistripp wrote:Sorry MK7 t350 XLWB Luton. Think. It's fwd. Looking at that diagram it's not the tensioner itself, it's the part that you fit the 1/2 inch bar into.
A Luton won't/cannot be FWD, does it have twin rear wheels..??
The part with the 1/2" drive square "is" the tensioner, the pulley is separately replaceable.
Postby enjoythistripp » Tue Aug 16, 2022 6:34 pm
Correct, red oops. I know a Mk5 like the back of my hand but the 7 is an unknown beast. Tensioner, alternator and belt £330. Ouch.
Then to try and find the oil flow pouring out the engine :(
enjoythistripp
