Timing chain cover gasket
Postby ezimoto » Wed Aug 17, 2022 8:18 am
Hi guys
May have been asked before but I didn't find it.
Has anyone tried using the gasket supplied with pattern timing chain covers rather than using sealant?
I have one to do soon and was tempted to give it a go, would certainly make it easier for the next person who had to remove cover for any reason.
Look forward to your thoughts.
ezimoto
Re: Timing chain cover gasket
Postby knobby1 » Wed Aug 17, 2022 9:04 am
Never used a gasket...even when it was supplied with the new cover. Always used sealant and never had an issue. Ford themselves use sealant.
Postby ezimoto » Wed Aug 17, 2022 8:59 pm
Thanks for the reply.
I've never had a problem with sealant either but it would be nice for the next person to be able to reuse the cover rather than bend it because the sealant sticks so well.
Was just curious if anyone had tried the gasket?
ezimoto
Postby knobby1 » Wed Aug 17, 2022 11:52 pm
ezimoto wrote:Thanks for the reply.
The covers are cheap as chips to buy...How often do you plan to remove the timing cover..?? My neighbor has a 2000 Mk6 Transit and it's never had the timing cover off. :shock: Only has 120k km on it though.
Postby andz327 » Thu Aug 18, 2022 8:39 am
Tried same type of gasket on sump.....it was p!sh
Sent from my SM-G975F using Tapatalk
andz327
