TRANSIT BONNET KEY STOPPED WORKING
Postby gsc1ugs » Wed Sep 14, 2022 11:35 am
My Key wont open the bonnet, cant remember if its left first or right but either way it aint openning, how can i get in to replace lock, do i drill out the barrel?
gsc1ugs
Re: TRANSIT BONNET KEY STOPPED WORKING
Postby metalworker0 » Wed Sep 14, 2022 12:29 pm
I would try squirting wd40 into what you can see of mechanism, plus down the barrel ...operate (turn lock) several times whilst pushing on the bonnet a few times.
if it then comes loose and opens. you then can get at it. disassemble it and free it up and lube it properly.
The first turn clockwise should release the bonnet. second turn anticlockwise should release fully.
all the best...mark
Postby gsc1ugs » Wed Sep 14, 2022 12:36 pm
Ive got it open, squirty and banging on bonnet, ive doused it with LUBE hopefully will open again, think i'll get new lock
gsc1ugs
Postby Altransit » Thu Sep 15, 2022 11:41 am
I would try a newly cut (unchipped) key before to go to the trouble of replacing the lock.
I had 3 keys for my Mk6, none of which would open the bonnet, and all of which operated all of the other locks. I had a new basic key cut which worked straight away, which I kept, hidden, inside the van for bonnet opening.
Worth a try maybe :?:
Postby roviw » Thu Sep 15, 2022 7:49 pm
I had this on my previous transit, it was actually not the lock at fault, it was the key was very worn, it still worked perfectly well in the ignition though. I got a replacement key blade cut and the new " sharp edged" key worked a treat for the bonnet , local key cutting place charged about £12 for a blue transit type blade.
oops just noticed a previous comment said the similar thing !!
2008 LWB 2.4 140bhp med roof 350 rwd Pale metallic blue fully loaded !
roviw
Postby ned » Thu Sep 15, 2022 8:13 pm
I had that on my ol’ mk6, I just took the latch off and threw it away, fitted some bonnet pins instead.
viewtopic.php?f=27&t=209987
viewtopic.php?f=27&t=168296
ned
