Hi all,
I have a 2.2 2007 SWB FWD transit (100k miles on clock), which has trouble starting up. Once it does get going it runs fine.
I thought it was the battery, since it kind of seems to be getting worse on colder days, but actually it has still been quite warm here in the UK the last few weeks, and still seems to be getting worse, or at least not improving. I have a leisure battery and starter battery both under the drivers seat, with a split charge system (voltage sensitive relay) and fusebox (feeding lights, diesel heater etc) sitting on top on a wooden panel, which I installed myself a few years ago when I bought the van - never had any issues with it.
I disconnected the whole leisure battery system and monitored my start battery for over a week or so, in fairly cold weather:
- Measured voltage was about 12.6 V - seemed healthy.
- Took the battery out and charged it in my house with a mains battery charger. Voltage after full charge was 13.39V.
- With no load, 2 days later, the voltage was 12.68V
- 4 days later 12.63V
- All seems fine so far.
- Gave another full charge on the mains charger, and connected back in van (no leisure battery circuit connected).
- After some short sparking when connecting, initial voltage was 12.55V
- 1 day later, 12.46V
- 3 days later, 12.4 V
- 5 days later, 12.35V
- conclusion is that battery seems to have healthy voltage, seems to charge ok, seems to hold its charge ok, and there does not seem to be any excessive current draw in the van draining the battery.
- Started up van with battery connected after 5 days (12.35V) and has a very slow start before eventually turning over.
I did already put a new starter motor in myself about 2 years ago, and don't drive it regularly, and mostly longer journeys (used as a camper on weekends only pretty much), so that should be ok I would guess.
I wondered if there is some high resistance between the starter battery and starter motor causing large voltage drop, so I did a voltage drop test with my Fluke 87 meter on peak min/max function, and measured 7.8V drop on one go, and 6.9V drop on another go between the battery positive terminal and starter motor positive terminal! This seems way excessive to me, but apparently this has a resolution of 250us, so may just be capturing some very fast transient (would like to get a scope on there if I had one). What should a healthy voltage drop be? I would guess only 100-200mV?
The wiring in the manual only shows Fuse 1 and a couple of connectors int battery fusebox between battery +ve terminal and starter motor +ve terminal, and between the switched input is shows starter relay, R4, passenger fusebox F77, and charger relay R1, but all fuses seem fine.
I might try disconnecting the terminals of the starter motor and cleaning with a wire brush, maybe putting a spring washer in there. I do have a small oil leak in the engine, which seems to drip down onto where the starter motor connections sit, so maybe I could try covering it after cleaning with some electrical tape.
Anyone had these issues before? Anything else I can try?
Don't want to buy a new battery only to find out that is not the issue.
