Ford transit mk6 2.4 clutch problem
Postby Dannyk1986 » Fri Nov 18, 2022 1:19 am
My ford transit rwd tipper 90 2003 mk6
Had a reconditioned engine fitted nearly a year ago now and was advised to get a new clutch installed! I picked up my truck and was told the clutch needs bedding in its been nearly a year now and got worse... I can't get hold if the parson who installed it nor has it got any better please help if can? love my baby just feed up with people thinking it needs bleeding!! this has been tried so many times
Dannyk1986
Re: Ford transit mk6 2.4 clutch problem
Postby Dannyk1986 » Mon Nov 21, 2022 1:01 am
Please help? My much-loved 2003, Tipper rwd 2.4 duratorq, 90.
Had a engine change about 6 months ago and I also agreed to have a new clutch fitted. When I picked my truck up I was told it is little hard to put it in gear but will get better after bedded in! Please help its got worse and I can't get hold of the fitter who carried out the work.
Please help me? if you know anyone in the essex area who can help please forward this on or reply with their contact details. Thanks Dan
Dannyk1986
Postby Jim Archer » Mon Nov 21, 2022 10:02 am
Sounds like the nose bearing in the crank might be failing.
Jim
Mk7 140 Jumbo - Vantunered.
289,000 and counting.
Jim Archer
