Hello,
I have had a Mk7 for last couple of years and have always had starting issues with it. I change the starter motor and hasn't cured the problem. It has gotten worst, I have just replaced starter cable but still getting the click with no starting... It does eventually start with a jump start.
Is it likely to be an earth problem, is there a way to test with meter? Also are there any started relays I could replace to rule out? Thanks
