Mk6 duratorq and if we bleed the injectors theres mostly air and very small amounts of fuel at the injectors whether we hand pump at the fuel filter or try to turn engine over.
However cannot see where air might be getting in, any ideas?
No leaking fuel around the filter, does that mean filter is airtight?
Any tips on how detect leak?
If there's air and hardly any fuel when hand pumping at the filter, does the mean the fuel pump is not the problem, or could it still be the fuel pump that's faulty?
Photo of filter/ housing attached.[
