Uncle_Fester wrote:Hmm, could it be the reciever getting "weak"?
All I've done recently is replace the overhead interior light bulbs with led bulbs and strangly the following day fuse 78 (central locking) blew... I replaced it and all seems OK apart from the reduced range on the key fob... which started as an issue before the fuse blew.
Today I replaced both batteries as one was only giving about 11.5 volts (don't know which but starting always seemed a little slow, so likely the stater battery) but the low fob range remains..
I wonder if it's worth taking out the cab lights and disconnecting the wires? See if that makes any difference? I might try that with mine next week as this weekend is busy busy?
Unlocking and starting are always a bit sluggish when the batteries get low, that's why I charge mine up every couple of weeks (The van doesn't go anywhere these days) But the low voltage doesn't seem to make the remote range any less, or better when charged.
