Mk7 transit 2.4 to 3.2 conversion
Postby Trey99 » Sat Nov 26, 2022 11:32 pm
Good evening everyone,
I have a 2.4 100ps 08 mk7 transit I use for my mobile mechanic business. It is slow as a slug especially up hills. I am interested in converting it to the 3.2 and wondering if anyone has done it and what I would need to do? I know I’ll need the engine, box, gear cables, front end and wiring loom and possibly the ecu but I’m not 100%.
Any help would be much appreciated.
Trey99
Re: Mk7 transit 2.4 to 3.2 conversion
Postby v8dave » Sun Nov 27, 2022 4:14 pm
Have a look in the members projects section, 'Agent Orange' by Martynx and there are probably others.
mk7 08reg 2.4 T350 LWB MHR RWD
mk6 X reg 2.4 T350 LWB MHR RWD - scrapped
mk4 J reg 2.5 L300 LWB MHR RWD - sold on
Notice a trend there ? not too big and not too small
v8dave
Postby GrahamSwindley » Sun Nov 27, 2022 6:02 pm
Martynx has definitely done this but it’s not a Saturday afternoon jobby.
GrahamSwindley
Postby knobby1 » Sun Nov 27, 2022 7:52 pm
Trey99 wrote:Good evening everyone,
Can indeed be done, gearbox and shift cables etc should be the same....But the 100 is a 5 speed....the 3.2 was originally a 6 speed....should still work though. Obviously the 5 cyl engine is longer than the 4 cyl and all the front end gubbins will need sorting. As mentioned Martyn "Vantuner" has done it.
Postby ossie cossie » Mon Dec 26, 2022 2:55 pm
worth a try on a MK6 as well. ?
ossie cossie
Postby knobby1 » Mon Dec 26, 2022 9:53 pm
ossie cossie wrote:worth a try on a MK6 as well. ?
Possible...but will be major surgery with nothing left of the Mk6 engine bay gubbins.
Postby Airthies » Tue Dec 27, 2022 12:33 pm
Your better getting a full Mk7 3.2 and grafting it into a Mk6
Possibly easiest way to do a mk7 conversation too.
It's been done before by others but think Agent Orange is the best documented.
As a side note you may have to factor in having the 3.2 rebuilt as the are prone to blowing between cylinders and require the block to be skimmed to rectify.
Sent from my Armor 8 Pro using Tapatalk
Bikes, yes, a few bikes.
V86+patch
V86.04
X-Prog
C81
Airthies
