by pakunalle » Sun Nov 27, 2022 6:53 am
Hello everyone,
First off, English is not my first language so sorry if there are some issues in my wording. Also, I work at a Ford dealership with parts but I'm not very experienced with the field yet, but do have access to all the workshop manuals.
I got a 2001 Mk6 2.4 120hp(with turbo, EGR, no AC) engine code D4FA. Last summer started hearing some slight ticking noise from the engine which slowly turned into a knock. Checked injectors, hydraulic tappets, injection pump solenoid resistance, all good. Took out oil pan and found scraps of bearings. Took apart the front end of the car (I have no lift) and pulled out the engine and the transmission, and found out that 3rd cylinder piston's upper bearing is done.
I bought an identical engine off a donor van to replace my engine with. I swapped starter, inlet manifold, EGR, valve cover and some water pipes from the original engine because they were in much better condition and because my original EGR was plugged and I want to keep it that way. Some wires were cut from the donor engine so I had to solder new connections to the wires that go to crankshaft position sensor, and the two wires that go to transmission from the same loom (speed and reverse sensors I think?).
Put everything back together, used a hand pump to fill the fuel line between fuel filter and injection pump (the larger line, I assume thats the one that feeds the fuel to pump cause the hand pump didn't fit the smaller one). Didn't bleed the line between tank and fuel filter cause I didn't have to take those apart anyway, should be fine? Workshop manual says that some early 120hp versions are fitted with an electrical fuel pump on top of the filter, and there is a sideways cylinder-shaped plastic casing on top my filter so figured that might be it? Turned key to position two but there was no whirring sound or anything at the filter so I'm not sure if that's what it is. Anyway, I continue to loosen up injector pipes one by one and doing short starts to bleed the injector pipes til fuel came out on top of valve cover. The fuel was a bit foamy, so there was still some air in the system but don't think there was much. Tightened the injector pipes and tried starting but the engine wont run. Also some slight smoke came out from between engine and transmission after running the started engine, didn't smell like anything really, think it might just be some oil burning off the starter/flywheel area?
Is there something obvious I'm missing? Original ECU is in place, but injection pump is the one that came with the donor engine. Are there any compatibility issues between my original ECU and some parts that came with the donor engine? Workshop manual also says that when installing the new engine you should remove the crankshaft position sensor and set the engine to a certain position but it doesn't say why. I never removed the injection pump so I figured I don't need to mess around with timing right? Could still be that the injectors on the donor engine are busted, or injection pump is faulty. I have 4 tested and working injectors and a working pump from the original engine that I could swap in there. Could be that I messed up the fuel line bleeding and can't get enough pressure in injection to make it run? Unfortunately I have no error codes to present to you folks, because I don't own a tester of any sort and the car is immovable right now.
I appreciate any wisdom I might receive from the Transit Wizards around here, thank you in advance!
