Hi
Great forum - the advice on here has has saved me a few Bob over the years.
I have a problem with my 2008 Mk7 t330 fwd van and I'm wondering if anyone can help point me in the right direction.
It's suffering from power loss when accelerating once warm. It's gradually getting worse.
When it started it would be just a blip but now it's more like you will be driving along and then put your foot flat to the floor and nothing happens.
When you turn the engine off and restart it it starts fine and the problem seems to go away for a few miles.
It's starting to get a bit iffy as when you go to pull away at a roundabout you never know if you have the power to pull away quickly enough !
I did have Martyn at vantuner change the prv and scv and do the updates around 3.5 to 4 years back as it was hunting and stalling when coming to a stop at a junction.
Also had a new egr valve around 2-3 years back from my local garage (non genuine part I think).
I changed the fuel filter with a genuine ford one around 5 months back.
There are no codes showing and no lights on (had a fella check for me when he replaced the brakes a couple of weeks back).
It does appear that the injector seals need replacing as it is slightly damp on the tops of them so I will need to get that sorted but I was wondering if there are any members with IDS that are a bit handy in the Hertfordshire area - I'm in Borehamwood - that I could take it to as I would much rather pay them than have my pants pulled down at Ford's !
Looking at other posts it does sound like it could be the scv but don't really want to throw tons of money at parts that don't need changing.
Any help or advice would be great guys
