2012 mk7 bonnet not closing
Postby mtbcol1n » Fri Jan 13, 2023 11:05 pm
Evening all. Can you adjust the bonnet catch on a 2011 mk7 without removing the bumper or grille? The bonnet won't close completely and the key moves up and down if I life the bonnet up and down while closed.
Trying not to remove the bumper or grille as I've knackered my back and can't lift or move to much.
Cheers. Colin
mtbcol1n
Re: 2012 mk7 bonnet not closing
Postby tranmx2 » Sat Jan 14, 2023 11:26 pm
I'll get some images tomorrow.
These may do for now.
The two rubber stops can be screwed in/out.
2012 2.2 TDCi MK 7 E 5 100 HP - 350 3.5 tonne XLWB RWD Duratorq 2.2L CR TC 14 DSL 100/125 PS
Was DRRB 74 KW 100 HP 100 cv. Now CYR5 125 HP. PCM could still be for 100 HP. Siemens Continental fuel system.
OBD2 ELM 327 FTDI Forscan 2.3.46
tranmx2
Postby mtbcol1n » Tue Jan 17, 2023 11:46 am
Thanks tranmx2.
Some pics of how you get to the boots behind the grille would be great if possible.
mtbcol1n
Postby tranmx2 » Tue Jan 17, 2023 9:52 pm
Sorry didn't get the images - lots of snow roads closed.
tranmx2
Postby tranmx2 » Wed Jan 18, 2023 9:16 pm
https://www.youtube.com/watch?v=48K5qhf3xhY
The lock is bolted to the cross member - remove the 4 plastic bumper/grill bolts/screws - remove the 3 bolts at each end of the cross member - see vid.
If the lock does not release it maybe necessary to cut the area on the top of the bonnet above the top latch bolts. If the bonnet lifts 25 mm or more you may get up under and cut the latch.
tranmx2
Postby mtbcol1n » Fri Jan 20, 2023 11:39 am
Hi tranmx2
Thank you very much. Video explains everything.
As it's also bloody cold here I think I'll orde a new catch system and attempt it in the spring. I've sorted a temporary fix/ bodge by jamming a price of wood under the key insert to raise it up high enough to engage and keep the bonnet totally closed and locked. Bonnet edge is a bit high but it'll do until it's not -4° outside!
Thanks again for your help mate.
mtbcol1n
