Heater problem
Heater problem
Postby spainish steve » Wed Jan 25, 2023 9:52 pm
2008 Ford transit mk7 2.2 diesel heater not getting hot
Thanks in advance
spainish steve
Re: Heater problem
Postby dannyjw » Wed Feb 08, 2023 8:33 pm
Hen mine did that it turned out to be the waterpump.
Known fault on this engine, the impeller is made of plastic and the splines stip off.. still has sufficient strength to circulate the engine water but the heater feed doesn't get it fair share.
It will get worse and you will notice the water temp starting to rise.
If of course, that is the problem.
dannyjw
