by v8dave » Mon Jan 30, 2023 7:32 pm
Depending on you budget and how risk adverse you are.
New flywheel and clutch if your over 25K on the current set. You can do a clutch by pulling the gearbox, but it is much simpler to pull the engine so best to do it now.
New water and vacuum pumps, they are both in the engine oil system so if you need a new turbo cartridge they could be just as wrecked inside.
Ford manual says change the turbo oil feed if changing turbo.
New egr cooler, just because again it's easier now.
mk7 08reg 2.4 T350 LWB MHR RWD
mk6 X reg 2.4 T350 LWB MHR RWD - scrapped
mk4 J reg 2.5 L300 LWB MHR RWD - sold on
Notice a trend there ? not too big and not too small
