Frag wrote:The 2643 codes relate to the DPF being overloaded,needing a regen.
The 242 code relates to an exhaust gas temp sensor,which,if faulty is probably the cause of it not doing regens and hence the soot loads increasing till it’s in limp/reduced power.
trannyfreak wrote:In bigger sh*t now as the nut part has sheared off the sensor leaving the threaded part still in side the dpf along with the sensor
trannyfreak wrote:Just get the sensor part mapped out or the complete dpf it's self? Many thanks
trannyfreak wrote:Ah OK, could I not just leave the innards still in but still get it mapped out, or is that defeating the object?
