Hi guys and gals
I have this on going problem I hope you can help with, I have a 2010 2.2 semi high top mwb
I brought the van about 4 months ago with the abs and esp
Light on and after running forscan on it I found out that it was
The rear right speed sensor which I replaced and the light
Went out for about a week and then came back on so I put it
Back on the forscan. now this is where I get confused forscan
is not showing any abs or esp codes however it is bringing upa
code p0704 clutch switch circuit input, I have changed the clutch
switch but am still getting that code when I put the van on forscan.
Also when I clear the dtc's the abs and esp Light goes off but when
I drive 10yrds they come back on.
So my questions are......would the clutch switch circuit input
Cause the lights to come on and how do I fix this problem
Sorry if this has been answered before
And thanyou for reading
