Vibration in all gears
Postby GTransit » Mon Feb 06, 2023 12:37 pm
Hi again guys. Not having much luck with vans at the moment!
2011 Transit 2.2 FWD
Vibration / hum in all gears , at its loudest 2-3000 rpm
1st gear a little stiff to engage in comparison to other vans
Put the clutch down and the noise goes away. Maybe answering my own question here , but if the noise is going away with the clutch down can I be pretty certain it’s a clutch issue ?
GTransit
Re: Vibration in all gears
Postby metalworker0 » Mon Feb 06, 2023 7:39 pm
Look at the easy to get at stuff first ..driveshafts and cvs ..get under there start twisting, turning, tugging and levering, you are looking for slop, and metallic noises.
find nothing ...then you can look at the clutch , if DMF, it's that breaking up.
drive shafts being under power will make different noises than when not being powered
all the best..mark
Postby GTransit » Mon Feb 06, 2023 7:53 pm
Thanks - if it were driveshafts / cvs would the noise not continue regardless of the clutch being in or out ?
GTransit
Postby knobby1 » Mon Feb 06, 2023 7:56 pm
GTransit wrote:Hi again guys. Not having much luck with vans at the moment!
If you have a vibration/noise and the noise goes away when the clutch is down....your DMF might be failing, if fitted. How many miles on the beast..??
Postby GTransit » Mon Feb 06, 2023 9:58 pm
150k on it
I’ve replaced dmfs before due to rattle at idle , but this sound is new to me
GTransit
Postby knobby1 » Tue Feb 07, 2023 7:50 pm
GTransit wrote:150k on it
Hmmm...might be gearbox related, noisy when clutch is out, goes away when clutch in, 1st motion shaft bearing maybe.??
Postby metalworker0 » Tue Feb 07, 2023 10:06 pm
if mtx75 there is a bearing that fails first ....the reason is; its a sealed bearing and ford put it in there and no one knows why. bearing does not share gearbox oil like the others ..and revolves around in its own detritus.
Not sure, some have a plate over this bearing and it can maybe be accessed from the outside of the box.
all the best..mark
Postby GTransit » Wed Feb 08, 2023 8:36 pm
Hi guys
Removed the gearbox this evening.
Clutch fine , pressure plate fine , slave fine
DMF however has play side to side , and play up and down if that makes sense , as in pushing on it it rocks. In fact , the dmf has rotated to the point the bolts fixing it are not accessible unless i twist the front with a bar. Nice pile of dark grey dust landed on the floor directly under it too, on removal of the gearbox.
Are the symptoms described likely to be DMF ? I’m hoping so as I’d hate to replace it to then find out it was gearbox all along, though it looks very much like I’ll need to replace the gearbox regardless
GTransit
Postby metalworker0 » Wed Feb 08, 2023 10:32 pm
Well you've got the gearbox out ..
You can now do some checks
Alan Howatt shows how:
Here you see at the beginning about 3 mins into the video he is turning the input shaft and you can hear the roughness.
https://www.youtube.com/watch?v=1K79jMOPbuw&t=885s
note ..you'll be able to hear it better if on a table top ..as this amplifies the noise, drain the oil before the test.
it looks so easy to do the rebuild ..its worth doing, if you are capable and have the tools, if the vans covered high mileage like anything over 150,000..i would be doing it.
all the best...mark
Postby GTransit » Thu Mar 02, 2023 7:15 pm
Just to update guys :
Replaced the drivers side drive shaft due to noise when rotating the bearing. Weird as the noise would only happen if the bearing was rocked in a certain way.
Maybe I didn’t ever need to remove the box , but the DMF was humped anyway.
Hope this may help someone. Thanks for the help and advice.
GTransit
Postby andz327 » Thu Mar 02, 2023 8:38 pm
It's been your dmf, how could your driveshaft bearing effect it if noise changes pressing the clutch....
Some people just over think the problem , hope you replaced the clutch
Sent from my SM-G975F using Tapatalk
andz327
Postby GTransit » Thu Mar 02, 2023 9:13 pm
I could only think the bearing was rumbling more when under load from the engine
GTransit
Postby musicfunkydude » Mon Aug 31, 2026 9:58 am
Hi mate, I have the exact same problem right now on my mk7 fwd 133k.
I have a vibration in the steering wheel at idle and can feel it in my feet on the pedals.Everyone telling me it will be the dmf.I bought the van because I have the receipt for a new clutch/ flywheel 10k miles previous. I'm no mechanic but I went jnder the front and I can pull the driverside drive shaft in and out 3mm ? It clicks in and out when j pull it up and down.Is it possible it needs replaced.? Thanks George.
musicfunkydude
Postby metalworker0 » Mon Aug 31, 2026 2:01 pm
the drive shafts will pull in and out by the amount you stated with no faults on them .. thats how they are .. so you can check that off your list .
Postby andz327 » Tue Sep 01, 2026 12:46 am
musicfunkydude wrote:Hi mate, I have the exact same problem right now on my mk7 fwd 133k.
start your own post and mind include van year , hp etc
andz327
