Hello there I'm having trouble starting my mk6 transit 2.4
After running out of fuel I managed to get it started and running for only a day using some easy start but end of the day it wouldn't start again, so I checked all fuses and relays which were all ok, I then tried and tried again using easy start and even cracking open the injectors a bit still no luck in starting it,
I then plugged in a computer and it showed me code p1608-fuel injection pump signal watchdog
I suspect this wire is broken due to the code, could anyone please help and tell me what I should do please
Cheers
