Jm7812 wrote:Hi
New here, any help would be appreciated.
Brought the van in a state, had to rebuild the top end and it’s bad 4x new injectors. I successfully completed the pilot learn before realising I should have done the pump learn first.
Attempted a pump learn today and it’s failing after the temporary learn:
Fuel rail pressure sensor
Short to VBATT
See the attached image for more
I have traced the wires back as far as possible without completely disassembling the loom, no issues have been found.
Any ideas?
Were the PRV values reset before starting the learns..?? Were the SCV and PRV replaced as well..?? Were the injector "correction factor codes" put into the PCM using Forscan..??
Battery/s needs to be in very good condition & fully charged before starting the learns procedure or it can cause issues, or connect a jump pack during the learns.
