ECM access
ECM access
Postby Mark89dawson » Thu Nov 09, 2023 10:17 pm
I’m looking to check and maybe reset the as built data on my mk6 tdci for the ecm using forscan and a elm327 but there’s no option to do this I’m also going to need to change my axle ratio soon too can I do this somehow or do I need some other setup
Cheers
Mark89dawson
Re: ECM access
Postby knobby1 » Thu Nov 09, 2023 10:31 pm
Mark89dawson wrote:I’m looking to check and maybe reset the as built data on my mk6 tdci for the ecm using forscan and a elm327 but there’s no option to do this I’m also going to need to change my axle ratio soon too can I do this somehow or do I need some other setup
Cheers
ECM..?? Assuming you mean PCM, (Powertrain Control Module).?? They don't have an ECM or ECU as such.
There might be an option in the programmable modlues tab, you'll probably need the extended licence from Forscan for that if you don't see the options you require available....it's free for two months though.
