Hi all,
Hoping to get some help. I have a 63 plate Mk7 H2 L2 transit with a 2.2 6 speed RWD coming up to a 180k miles. I've had it about a year and used this forum to help with an EGR/hunting/lack of power issue.
So looked on some other threads with regards to key fobs and lock issues. Currently I am locked out of my van and can't get in at all. 1) Non of the buttons work on my fob. Did the tooth brush charger trick and have a £4 replacement blue top coming from ebay in a couple of days. No joy with the tooth brush charger (12 hours or more) when I use the the buttons so decided to hack saw it opening. I've got 3.2v at the battery and the associated terminals in the fob so that actually might be alright now/was always ok maybe.
The key is working manually to get the hood up and I put the van on charge through through the jump post and I'm getting 12.7v there but I think this is the back battery for the starting. it has been lazy starting recently but has always gone. I did recall seeing the radio reset so maybe the front battery is knackered. I can't load test the batteries as I can't get in the cab.
If the key opens the bonnet but not the drivers door (only key location) I suspect the barrel/central locking mechanism is tired/worn on the drivers door. I have used this in the past fine. When I try to use the key now I get nothing (don't feel any resistance or hear any noise) when I turn once to the right. I get a pathetic noise like central locking trying to do something if I do one or two turns anticlockwise as if locking. The noise of the motors comes from the rear and side door but I can't hear anything from the front driver's door and not sure about the passengers door. Can't find my spare - I use two and have a nasty feeling one is in the back with my tools!
I think I'm screwed bar breaking in. Anyone got any suggestions? I think if I could get into the drivers doors to at least load check my batteries and sort them out and then get it running I might be ok but I think i'll get new barrels and locks anyway. Are the two batteries conjoined or independent of each other? - is there a way to ensure I charge up the front battery?
Many thanks Rjsharpy
