Hello all,
I have a 2008/09 transit 2.2 FWD 140hp LWD. The issue it has is I have to accelerate the nuts off it to get any power from it. When it's not loaded is drives fine or better to say that it's less noticeable. But when I'm carrying a heavy load, you can really tell the lack of performance it has especially going up hills and I alway have to lower by at least 2 gears to be able to maintain the speed/revs or to just simply get any power from it. Fuel consumption is pretty bad. This is a fuel related issue I believe as when I start the van from a cold start, it turns over but doesn't actually start the engine then ill try again and it will start but the revs will slowly lower, the engine judders, then clonks out. I find that I have to press the accelerator pedal and start it at the same time and it usually starts after the 3rd attempt and then that won't happen again until I start it from cold again. It only happens on cold starts. Would anyone know what the issue could be? I did change the fuel filter 2 years ago as i couldn't get the engine to start and that solved that problem. I really want to get to the bottom of this as I have a 3000km journey to do soon. Just to note, I have forscan and no codes come up!!!
Any help will be greatly appreciated.
Many thanks.
