clydebuilt wrote:Another noob question, I've had a search on the forum and done some Google-fu but can't find the location of the starter motor. Until Mr Hayne's book arrives, can someone point me in the right direction so I can give it a knock pls?Cheers!Andy
clydebuilt wrote:Cheers for the starter location clarification knobby1
Apologies for the delay in posting an update; work and sh*t weather have conspired to foil me. Today I had some time to spend on the van. So, following the advice above, I wiggled the key in the ignition a few different ways but this made no difference - still no crank. I then pulled the driver's seat forward, removed the batteries and unbolted the main battery earth. The battery terminals and earth didn't look corroded but I gave them a wire brush to ensure they were shiny before reassembling - https://www.dropbox.com/scl/fi/r54jkx7w ... zr04b&dl=0, https://www.dropbox.com/scl/fi/5lihiupk ... e8pzs&dl=0.
This also gave me an opportunity to clean out all the crap that had gathered under the driver's seat! I also charged both batteries while separated. Both are showing around 12.4v. Sadly, this hasn't made any difference to the underlying problem as there is still no starter motor activity.
I guess the next step is to give the starter a knock and if this makes no difference I'll check the starter motor connections as transmx2 suggested.
The Haynes book has now arrived so I'll check that for starting problem troubleshooting too.
Cheers!
If the starter motor is stuck - put the vehicle into 1st, 2nd or third gear and push/pull the vehicle forward and back - if it is on the flat surface. Have blocks to stop it from rolling away or a small person who can apply the brake inside.
clydebuilt wrote:Cheers knbby1. Good point mate. Is there a way to test this, if the other tests are inconclusive?
Cheers!
. Thanks for the tip metalworker1. Quick question on this; where do I out the spanner / ratchet as Google turns nothing up. Again, apologies for noob questions. I'm writing all of this down!You can turn the crank about a quarter turn clockwise with ring spanner or ratchet ..this may help .
Yeah, sorry if any of this is unclear as I'm learning as I go. The voltage measurements I took this afternoon were with the solenoid wiring still connected and I just touched the + probe of the multimeter to each big nut of the solenoid in turn and had the - probe connected to the starter earth connection; so the voltage drop is most likely resistance of the solenoid itself. I couldn't figure out how to get the nuts off the solenoid to test out of circuit. Seems the starter in a FWD transit is less accessible than a RWD. Definitely no "good wack" from the solenoid when the key is turned as I had my head under the van when measuring the voltage. Totally agree that this troubleshooting takes time and I'm taking plenty of notes!You need to portray exactly what you have done.
