Leyland2020 wrote:2010 2.4 rwd, high top,lwb 170,000 miles .ex garec hire mess van , used as a rally barge . Driving home from a classic rally a top end tapping noise appeared with a loss of power and white smoke from the exhaust . at times the noise would disappeared at low and high revs ,dependant on the road conditions (ie strain on engine) . So i covinced myself it was injector washers ?. Have now changed them no3 injector washer was squashed and v dirty and had marks on injector body as if had been moving in the clamp . Now the bugger wont start . she tries to fire ,somtimes the starter kicks back as if she,s on her way other times starter sta
s in and she trying but will not go ,getting white smoke out of exhaust (un burnt fuel?)
List of thing i have done -
removed and filled fuel filter (was empty) no difference
put hand primer on the nearest pipe /left hand side pipe to pump on fuel filter housing ,hand primed untill fuel was coming out of fuel filter housing (then blocked off)
Cracked all 4 injectors individually ,all have fuel and pulsing with fuel as engine is cranked over
Going to do a leak test next , But any ideas out there befor having to remove injectors and a compression test ?
Many thanks in advance
Leyland2020 wrote:thahks for reply , whats the tech needed to get the fault codes , im old school and up to now have always figured stuff out. most of the cars i work on are pre ecu . ie mantas ,205s and minis . The transit had both batteries replaced pre winter and both give good voltage readings and alternator working fine. i dont know if this means any thing but ,i have tried a squirt of easy start ,but the same again she tries ti fire but wont carry on .ummmm
