TheCake wrote:i have a single battery mk7 i want to add a second battery just to increase capacity, what would be the correct way of wiring it up?
TheCake wrote:think ill go the mk6 route for cost reasons, ive got a second battery that may need replacing anyway, tried the bar thats in there and it holds both batteries securely i dont have a plastic cover (not sure where single one went either as i had to take the thing off so many times to jump it in the past) no clue what the twin vent tube looks like, ive had a perusal on ebay but im stumped, i know this sounds silly but how should i connect them so i dont bugger the van?
TheCake wrote:so by parallel im assuming batt 1 is connected to existing cables then we go pos from batt 1 to pos batt 2 and neg from batt 1 to neg on batt 2, as from iirc running them in sequence increases voltage? which we dont want we just want a higher ah (capacity)
