Gidday, my 2011 Mk7 RWD transit always had a few issues starting clean. It would quite often turn over slowly or sometimes not start first try, as if low battery, but would always start after a few tries.
I have the dual battery setup and noticed that the previous owner had changed the rear starter battery, but left the original front one, which was now dead. I replaced the battery thinking the dead battery may also be dragging down the newer starting battery.
When I went to start after replacing, there is a sound as if the engine is trying to turn over, the van jolts a bit, but wont turn over, then a releasing sound when the key is turned back. Sound clip when starting below for reference. Any ideas what it would be? Starter motor packed in?
Cheers
Whal
