2.2 tdci rocker cover breather
Postby Embram » Tue Jun 25, 2024 11:17 am
2.2 euro 5 2012. Can anyone tell me if the pipe from the rocker cover breather is controlled by a valve. Are you able to blow and suck through the pipe?
Embram
Re: 2.2 tdci rocker cover breather
Postby metalworker0 » Tue Jun 25, 2024 1:44 pm
There are spears to be a set of orange one way rubber valves on the underside of it
These have been found as fallen out when people take the cover off ...so the only way to find out if they are still there and in position and doing job is to take the cover off.
Postby Embram » Tue Jun 25, 2024 4:12 pm
Mark i purchased a cheap (mistake) rocker cover and fitted it. After a few miles the dip stick blew out releasing cc pressure. Removed the rocker cover dismantled the diaphragm and found the port integral to the diaphragm did not exist (it had not been machined during manufacture). Therefor not allowing it to breathe. Note! (anyone purchasing one of these rocker covers should check it before fitting). 2 of the 3 small bleed off (drain)valves which you mention were missing from my original rocker cover. I intend fitting the 3 new orange/brown coloured rubbers to my original rocker cover and refitting the original cover. Regards Eric. ps I received a full refund for the faulty rocker cover and was told not to bother returning it. This makes me think the seller possibly new some of these cheap rocker covers are faulty.
Embram
Postby vansit1 » Thu May 08, 2025 12:40 pm
what should be the part number(s) for this kind of stuff?
vansit1
Postby metalworker0 » Thu May 08, 2025 2:32 pm
That depends on what year your van is and if euro4 or euro5.
Drawings of them on the parts lists, are a bit vague to determine this .
CAUTION - ebay sellers put both part numbers in to get you to look at them
But as i said ..euro5 has orange rubber things on the underside of it
euro4 a different design..no orange rubbers
You'll see on ebay when you look at the different pictures within the listings
Postby vansit1 » Thu May 08, 2025 4:03 pm
ok, i thought that e4 should have it too
vansit1
Postby metalworker0 » Thu May 08, 2025 4:34 pm
Another problem with the part numbers is you have two categories for 2000 - 2006 years
Transit FY 2000 - 2006
and
Transit GY (Turkey) 2000 - 2006
Postby tranmx2 » Thu May 08, 2025 6:34 pm
2.2 euro 5
http://www.catcar.info/ford/?lang=en&l= ... NysxMzM%3D
CATCAR better to put the VIN in. Above shows a rocker cover 6K271 COVER is for E5 2.2 125 HP.
https://www.google.com/search?client=fi ... d&q=catcar - click on FORD.
https://www.catcar.info/ford/?lang=en - put the VIN in. If no VIN go to TT9 image near the bottom and click on that then put in the info'.
Power train engine and covers and gaskets.
2012 MK 7 E 5 100-350 3.5 XLWB RWD Duratorq 2.2L CR TC 14 DSL 100/125 PS
Was DRRB 74 KW 100 HP 100 cv. Now CYR5 125 HP. PCM could still be for 100 HP. Siemens Continental fuel system.
OBD2 ELM 327 FTDI with switch from Tunnel rats. Forscan 2.3.46
tranmx2
