MK7 media stalk - anyone had a fault with theirs?
Postby snowjoe » Sat Oct 19, 2024 10:00 am
Our media stalk won't work, doesnt change track or volume etc. It did in our old van.
I bought a replacement (used but working), no change. I now took one from a friend's van (known working) and tried that, no change.
Just wonder if anyone knows what to try next?
thanks
2009 MK7 Crew Bus, soon to be a 'camper' hopefully, so I can keep up with tosspots on bicycles
snowjoe
Re: MK7 media stalk - anyone had a fault with theirs?
Postby loot » Sat Oct 26, 2024 11:22 pm
The media stalk has only 2 wires and they go directly to the facra connector the block on the radio. There's either a bad connection between the stalk and the radio or the pins have been removed and put back wrong or there's corrosion/problem with the radio.
Ids map here
loot
Postby snowjoe » Tue Nov 05, 2024 12:59 pm
Thank you very much Loot
snowjoe
Postby vansit1 » Sun Jun 07, 2026 10:31 am
where can i get the 16 pin female plug chart and does that have the alarm pin too?
vansit1
