Mk7 oil leak! Will the rocker cover cause an oil leak?
Postby Ianvilla08 » Thu Jan 16, 2025 9:56 am
Hi guy I'm wondering if anyone can help, I have a bad oil leak on my mk7, could this be cause by the rocker cover gasket? Or would this only be a minor leak from the rocker cover. It doesn't leak much when it's been sat for a while only really when it's running, I have attached some photos cheers
Ianvilla08
Re: Mk7 oil leak! Will the rocker cover cause an oil leak?
Postby DanMK7uk » Thu Jan 16, 2025 2:10 pm
It certainly can, as can the cam cover / rocker gasket, the cover itself, injector seals so on.
Best thing to do is get it all cleaned down, then you can keep an eye on where its escaping from. If not already obvious. Is the top of the cover wet ? Is it “breathing” heavy from the filler cap when removed ?
Iv used non genuine covers no problem, but cover gaskets iv always used genuine ford. The cheap gaskets are in my experience a hassle/ incorrect size / deformed etc. never again.
Goes without saying, keep an eye on your oil level meanwhile.
Cheers
DanMK7uk
Postby Kimbyyri » Fri Jan 17, 2025 7:45 pm
I had the same. Egr pipe leaked.
Kimbyyri
Postby knobby1 » Fri Jan 17, 2025 9:42 pm
Kimbyyri wrote:I had the same. Egr pipe leaked.
EGR shouldn't have oil going through it....and it has oil all over the top of the engine running down.
Postby andz327 » Sun Jan 19, 2025 2:20 am
Holy fook that's a lot of oil, think injector seals are well fook, if it was just that top corner the oil filler neck seal is common but it's over the whole top, you'll start getting alternator problems with oil contamination on it brushes and starter motor won't be far behind it as well
andz327
Postby Kimbyyri » Mon May 12, 2025 3:04 pm
This is my transit mk7 2009 350000 puma 140hpImage
Kimbyyri
Postby vansit1 » Thu May 15, 2025 2:34 pm
je, probably cam cover, plus both injector seals
vansit1
