Ford transit mk7 inner rear arch
Postby audvaldid » Thu Feb 13, 2025 2:47 pm
Hi all,
Has anyone info where to buy a wheel arch?
Mine has a case of rustitus...
audvaldid
Re: Ford transit mk7 inner rear arch
Postby Parky7 » Thu Feb 13, 2025 4:19 pm
Just google it
Loads available from different sources or eBay….
Or weld a plate over it…
2010 - MK7 100/350 LWB Hi-Top
V-Strom 650
KTM 390
Parky7
Postby DanMK7uk » Thu Feb 13, 2025 4:23 pm
audvaldid wrote:Hi all,
Only ones iv seen are RWD. Must be different in some way. Whats yours ?
DanMK7uk
Postby audvaldid » Thu Feb 13, 2025 4:26 pm
Mine is awd. But it should not matter.
audvaldid
Postby audvaldid » Thu Feb 13, 2025 4:28 pm
Parky7 wrote:Just google it
I was not able to find this part on ebay... was hoping that I could just replace the whole part.
audvaldid
Postby DanMK7uk » Thu Feb 13, 2025 5:32 pm
https://www.ebay.co.uk/itm/144952594706 ... gINh_D_BwE
According the description there is a difference
DanMK7uk
Postby andz327 » Thu Feb 13, 2025 7:42 pm
That's an easy repair without buying full tubs
andz327
Postby Parky7 » Thu Feb 13, 2025 7:51 pm
As above, very east repair… I think you could get any arch and make it fit with a bit of fettling :D
V-Strom 650
KTM 390
Parky7
Postby DanMK7uk » Thu Feb 13, 2025 7:51 pm
Agreed, 90pc of arch is ok it seems, just make a wrap round piece, prime and paint.
DanMK7uk
Postby andz327 » Thu Feb 13, 2025 9:28 pm
DanMK7uk wrote:https://www.ebay.co.uk/itm/144952594706?mkevt=1&mkcid=1&mkrid=710-53481-19255-0&campid=5339017977&toolid=10049&customid=EAIaIQobChMI1N7HvonBiwMV8pJQBh3clBv-EAQYCiABEgINh_D_BwE&gad_source=1&gbraid=0AAAAAoWc2zfToGSFMRTePaFnYlAzdNcfT&gclid=EAIaIQobChMI1N7HvonBiwMV8pJQBh3clBv-EAQYCiABEgINh_D_BwE
Rwd floor is 4 inches higher than fwd, so rwd tub would be shorter height wise I guess
andz327
Postby DanMK7uk » Thu Feb 13, 2025 10:42 pm
Quite possibly, it’s interesting these always seem to go in that place as OP picture.
You wouldnt expect water to penetrate from inside.
DanMK7uk
Postby andz327 » Thu Feb 13, 2025 11:07 pm
Leaks through the seams eventually then there's condensation issues under the plywood edges where all the crap gatherers and stays wet , rear inner arch section where it attaches to the outer arch is another area that needs cleaned and treated, and waxoiled
andz327
Postby DanMK7uk » Thu Feb 13, 2025 11:29 pm
andz327 wrote:Leaks through the seams eventually then there's condensation issues under the plywood edges where all the crap gatherers and stays wet , rear inner arch section where it attaches to the outer arch is another area that needs cleaned and treated, and waxoiled
Makes sense, i might get myself a cheap welder and learn. Bound to need doing at some point on mine.
DanMK7uk
Postby T350camper » Fri Feb 14, 2025 9:48 pm
Get a small piece of 0.8mm steel plate and make a patch. Not a big repair really. I'm new to welding, but bought myself one of these from Machine Mart (other retailers are available :lol: ) https://www.machinemart.co.uk/p/clarke- ... 103ng-230/
Few practice welds on some scrap metal until I got the hang of it...plus there are several really good tutorial videos on tinternet (Tim Welds is a good one...it's a bloke called Tim, and he, erm...well you get the idea).
Then make sure you carefully paint and rustproof the area. Job done!
2006 Mk6 T330 135bhp 2.4TDCI
T350camper
Postby DanMK7uk » Fri Feb 14, 2025 10:37 pm
Been thinking about one of them, easy to pick up using ?
I know little about welding, would that be ok for stuff that needs to be really strong or just for non structural stuff ? Arches etc ?
DanMK7uk
Users browsing this forum: baggyboy75, Google Adsense [Bot]
