Koraru wrote:Hey, I know there is many other posts on this, yet I've been in this battle now for almost 3 years and probably tried everything on the list.
The subject is a 2004 2.0tdci transit ambulance which they fitted with a HJBB engine for her retirement after which I converted her for a camper.
Drove for many years without major problems, the limp mode occurred once or twice but never became a thing.
Almost 3 years ago driving up a very steep mountain, I started to hear something like misfires, rattling, loss of power and dive in to limp mode.
Main codes shown were p1211 p0251
I clear them all seems fine until then next one limp mode.
Since then the car is throwing up the limp mode driving with in 5 min and even stationary when releasing the accelerator abruptly from 3000rpm, the gauge lands on the bottom and then chokes down lower firing of the limp mode.
Sometimes I can do it 20x and it seems fine and sometimes it's a direct stall.
At this stage I:
Changed accelerator pedal
Checked all the fuel lines, tank..
Changed the diesel filter
Fitted new delphi injectors
New Valve on the delphi fuel rail
New delphi pump with all valves and sensors
New turbo
New map/maf sensors
Checked all the air pipes
New Crank shaft sensor
Cleaned the egr
Checked all the ground cables.
Checked the clocks for cold connections.
Probably a few more things I don't remember now.
What did I miss ?
Meanwhile my Canarian mechanic stripped the old ambulance electrics installation, as my battery kept getting slowly drained and is now convinced that it is an electrical problem that fires up the codes and wants me to get a new CPU to do a clone of the computer..
Other strange things happening like
The main cooling ventilator never worked, changed engine temp sensor, relay and thermostat. only Works if i short it.
Headlights turn on when I turn the ignition and the controller is off position.
The imoblizer lately also started to mess around.
I'm thinking maybe the mechanic messed up some connection?
Or could it all be signs of a faulty CPU for real ?
Maybe someone wants to come for a holiday to Tenerife and help me rule this out?
Its been so long and frustrating.. yet it feels like it makes no sense to give up at this stage as all is practically new. If it wasn't my camper maybe I would not be so sentimental.
Koraru wrote:Hey, thanks for the reply I manage to erase the fault codes every time. Untill the next coil comes up and the engine shut down the codes come back..
I was reading today about the ks sensor.
Would a faulty ks sensor could result it giving these codes
Koraru wrote:Chapter later ,
I've done more fuel tests directly from a fuel canister and little filter to the high pressure pump and the car behaves exactly the same stalls with the limp mode appearing. At this stage I really don't know where to look any more.. is there any way to test the computer of the car for malfunction?
Stevelien wrote:After replacing almost the same thing as your Transit, I addressed the following issues, which now prevent it from going into limp mode:
1. I removed the diesel particulate filter after the catalytic converter and cleaned it (in reverse) with Mr. Muscle oven cleaner and a pressure washer. It's an old-school diesel particulate filter without regeneration, so it gets clogged with diesel soot. It looks like an intermediate silencer, but it isn't. You can just remove it; it's the first part after the catalytic converter. I'm sure your HBJJ Mondeo engine also had this diesel particulate filter from the factory in 2004. So there are no sensors or hoses on it, just like there are no sensors on the catalytic converter. If it's clogged, you get a strange turbo pressure buildup via the EGR, which your MAF sensor after the intercooler reacts to by throwing it into limp mode. It's essentially too clogged with diesel soot after all those years and kilometers. I've checked with Ford Netherlands, and you can't buy a new one anymore, but as mentioned, it's easy to clean yourself. A dutch Transit 2.0tdci Mondeo exchange engine owner in a 2003 Transit had the same with it and it was his solution also. Some forum mebers deny yhe existence of a particulate filter in a 2003/2004 Ford engine but is a true particulate first generation filter.
2. Cap the EGR valve with a blanking sheet. It's vacuum-controlled, so you don't need to write it to the ECU. This will prevent it from leaking even after you've cleaned it.
Even if it's cleaned, it can cause strange errors in pressure buildup. Blanking plates are available on eBay, among other places. Be careful not to buy one for the 2.2d engine, which came later, as they have different dimensions. Google "Ford 2.0tdci 2003/2004 FIFA" or "Jaguar X-Type 2.0d" EGR blanking plate.
3. Try turning the diesel filter pollution meter upside down, if one is also installed on this HBJJ engine, because it draws in water from under the hood during and after rain. It's a red-yellow, transparent piece of plastic with a black knob and a piston inside it that measures the vacuum after the oil filter. In the factory-installed position, water falls on it and (especially when testing it) sucks water into the diesel line leading to the pump. You can easily turn it 180 degrees on the rubber hose. I discovered this because I also kept experiencing malfunctions during and after heavy rainfall driving or parked.
4 From your story, I gather you've installed four new Delphi injectors. I really hope they're really new, because some companies perform shoddy overhauls with Ali parts that don't work properly. I bought a "brand-new" injector from France that didn't work properly and after opening I discoverd these wrong Ali parts. I also bought a reconditioned one from Germany that was partially reconditioned, without any replacement parts from Noozle. Now I've installed four brand-new Delphi injectors. A good set is currently available on eBay in Italy for a reasonable price of €200 each; these are 100% factory-new.
4 check all your relay and fuse contacts.
5 New replaced Turbo I read so no sticking vanes I assume, often also one of the causes.But check your vacuum line(s) to the actuator for damage.
Good luck, my 2.0TDCI engine runs like a charm now. If the above does not help, an damaged electric wire(s) can be the cause...
Stevelien wrote:2. Cap the EGR valve with a blanking sheet. It's vacuum-controlled, so you don't need to write it to the ECU. This will prevent it from leaking even after you've cleaned it.
