by Stevelien » Wed Apr 02, 2025 8:34 am
Yes indeed, it is in the oil (filter). This afternoon I'm going to add the oil (after drying the sump silicon gasket 24h) and drive a bit and check the oil filter for new small aluminum particles and eventually flush the engine. If there are aluminum shavings, it is often because a harder metal part is running against a piece of aluminum. The shapes of the particles I found is not from a broken connecting rod bearing or anything, I suspect these bearings are also made of a steel alloy. Engine is running well, Forscan cylinder power balance test was ok. The camshaft chain should be very worn to the point where it touches the crankcase or outer case somewhere, which seems very quick to me at this mileage. I suspect the gear of the oil pump or part of the once loose aluminum seal of the oil bottle that came with a previous owner's filling and is now pulverized in the engine.
I let know.
