Mk7 down on power
Mk7 down on power
Postby DanMK7uk » Wed Apr 02, 2025 7:54 pm
Hi everyone
Just picked up another transit. Mk7 euro 4 FWD 6 speed 2008. 2.2 300 “115” (i think
van feels rather gutless, in terms of get up and go… im having to gear change at 2.5 / 3 to get momentum.
my word its clean however absolutely fantastic condition. Not a builders van previously.
Its got a new ford fuel filter on
Showing no codes on forscan and live data stuff looks OK…
No smoke, no whoosh / boost leak sounds
Clutch does feel a little light, compared to my other van so i suspect it may need a bleed, it dont seem to slip though…
Any suggestions really? The van is to be a camper, speed not the priority but torque id like.. at empty im a little keen to investigate as when its built it will only be slower.
Appreciate any pointers guys
Cheers !
DanMK7uk
Re: Mk7 down on power
Postby knobby1 » Wed Apr 02, 2025 8:04 pm
DanMK7uk wrote:Hi everyone
Cheers !
Check turbo actuator is free to move. If possible, remove the rod from the wastegate arm and see if the little wastegate lever is free to move. Actuator itself may be munted too.
Postby DanMK7uk » Wed Apr 02, 2025 9:21 pm
Cheers knobby
Can you confirm mine has the actuator?
There is no plastic box like on some others ? Or was that euro 5 I can’t remember!
Do i still have an actuator?
Can i move the arm or try rather without risk of causing a problem? Ie will it reverts to normal position afterwards ?
Sorry for my ignorance
Cheers
DanMK7uk
Postby knobby1 » Thu Apr 03, 2025 3:57 am
DanMK7uk wrote:Cheers knobby
Cheers
Electronic actuator is only on the 130 & 140 Euro-4 FWD's, all others, 85, 110 & 115 are wastegate type turbos. The actuator is a "pressure" operated unit rather than the electronic unit....most people think they're a vacuum operated...but that's not the case. The little black hose gets it's reference pressure from the cold side of the turbo and when that reference pressure overcomes the spring in the actuator, it pushes the wastegate open.
Your turbo should look similar to this one if it is a 115:
Postby DanMK7uk » Tue Apr 08, 2025 12:15 pm
Thanks knobby, had a look today to find the arm has corroded and un attached from the waste gate flap. I assume my option is to just replace? It’s the round pin thats broken off the flap
DanMK7uk
Postby knobby1 » Tue Apr 08, 2025 7:46 pm
DanMK7uk wrote:Thanks knobby, had a look today to find the arm has corroded and un attached from the waste gate flap. I assume my option is to just replace? It’s the round pin thats broken off the flap
And there's your problem...If there is enough "pin" left, and the wastegateitself is still free.... some people have actually welded them back together...
Personally, I'd just fit a new turbo...but that's not always possible for some people due to cost etc...
Postby DanMK7uk » Wed Apr 09, 2025 8:55 pm
New turbo ordered knobby, thanks again.
DanMK7uk
Users browsing this forum: JRHartley, Trev_
