Trying to find some help. I have 2007 Mk7 2.2 rwd 81kw transit. I had the ESP and ABS light on on the dashboard. I managed to change the abs punmp - the abs light went away. The esp light stayed on. The forscan said that incorrect component installed C0063:4A-2B and C0063:08-2B Bus Signal/message failures.
Then bought new yaw sensor from brakers yard. Still the same errors. I did log the live data and yaw rate sensor shows movements. I tried to recalibrate yaw sensor, but it says conditions not met. What I am doing wrong?
I will put some pictures also to help to understand the problem.
How to make this to work and get the light to shut off?
Please help....
