Naylz29 wrote:IMG_1166.jpeg
Ok so I was panicking my turbo was on its way out, I’m getting a noise like someone slowly letting a balloon down. Anyway great news today I discovered it’s nothing to do with the turbo but is a small vacuum operated actuator which I believe is some kind of air purge valve?? Can anyone out there explain what this is and is it important?, struggling to find a part number for it so might just blank it off for now until I can source one.
Assuming Mk7..?? You don't say what you have..??
Its the heater tap, opens and closes depending on internal heater setting...you must have A/C..?? Doesn't look like the standard fittings though...looks like someone has been at it before.
Just reconnect the little vacuum hose....can see it in the second pic....this will be the hissing noise. If the valve is not working, just replace it.
The valves get brittle with age and can often crack/break....replaced mine about 18 months/2 years ago.
Gazzilions of them on fleabay...but they come with plastic or metal internal flap valves, try to get the metal one....plastic one will still work though.
eBay listingsLord Knobrot
